Slå selealarm til/fra
Indlægaf HCS » tors dec 03, 2015 11:49 pm
Da jeg købte min S-Max '08 i sommers, så syntes jeg at selealarmen var lige lovlig emsig og gik igang lidt for hurtigt.
Da den så oven i købet drillede lidt på vores sommertur til Italien, så fandt jeg nedenstående metode til at slå den fra.
Se link nedenfor:
http://www.supersej.dk/index.php/biler/ford-mondeo-mk-4/mondeo-tips-og-tricks/142-selealarm-deaktivere
Jeg har kopieret proceduren beskrevet i linket nedenfor:
Selealarm - Deaktivere
1.Apply the parking brake.
2.Place the transmission selector lever in P (Park) - vehicles with automatic transmission or the neutral position - vehicles with manual transmission.
3.Turn the ignition switch to position 0.
4.Close all the vehicle doors from the inside of the vehicle.
5.Unbuckle the driver safety belt.
Then:
1.Turn the ignition switch to position II. (Do not start the engine).
2.The safety belt warning indicator will extinguish within 10 seconds.
3.The remaining steps must be completed within 60 seconds or the procedure must be repeated.
4.Buckle then unbuckle the safety belt nine times, ending with the safety belt unbuckled.
5.The safety belt warning indicator flashes three times to confirm the belt minder status change.
6.To activate the belt minder, repeat Steps 1 through 7.
After confirmation, the deactivation / activation procedure is complete.
